Old 03-01-2013, 03:39 AM   #22 (permalink)
RedDevil
90 day: 56.53 mpg (US)
It sounds like you really want warm air before the engine gets up to full operating temperature.
If you really want air warmed by coolant before the thermostat opens then plumb in a second heater core off your exixting heater core plumbing and build an air intake for it.
Then your intake air temperature will rise along with your coolant temperature.
A radiator feed for the WAI does have some benefit in the transition. The effect of grill blocking/winter fronts however slows down the air entering the engine bay, That air will get heated up by the exhaust etc.; so if the intake feeds from the bay the temperature does rise more quickly, as was proven in earlier posts.
