Originally Posted by 320touring
On my e36 coupe, the Radio Ariel was built into the windscreen pillar- actually INSIDE the car..could you do something similar- really just a case of cutting the cable shorter and some earthing in behind a trim panel?
Looking for a replacement - there are shorter ones but the base is going to be tricky.
I'm assuming the hatch has some hinges at the top- can they be unscrewed and a thin piece of metal be inserted betwen the Glass and the hinge? means you could mount to those points, have U brackets of metal coming out, allowing you to build a frame off them? It may also mean the Kamm lifts up with the hatch and doesnt get damaged?
I've done a rough sketch.. (I'm closer to Piccasso than Monet..)
![](http://i1197.photobucket.com/albums/aa421/ikilminster/georgehat.jpg)
It is more or less like this, will take a ponder. I'm kind of reluctant to move the tailgate too much as the bugs are prone to leaky rears (steady) but mine is dry so far. And it is inside the warranty, and new, and shiney...
I did ponder replacing it with an (older) Diesel Aygo from Fife the other week...
