Old 11-24-2012, 05:15 AM   #241 (permalink)
The PRC.
Video of trip home - MPG has gone down (need to update log) because I'm going through town more now.
Old 01-21-2013, 03:42 AM   #242 (permalink)
The PRC.
From another forum, snow shaped by the wind on an Aygo which just happened to be facing into it.
Ponders.
Old 01-21-2013, 09:23 AM   #243 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Ponders.
Aygo "Breadvan" FTW!
a few bits of card could mock up a small kammback on the aygo a treat, it'd not even have to go much beyond the rear bumper..
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 01-21-2013, 10:25 AM   #244 (permalink)
Igor - '07 Toyota Aygo
90 day: 63.4 mpg (US)
Ponders.
Very interesting. Thanks for posting.
Old 01-22-2013, 03:50 AM   #245 (permalink)
The PRC.
Also an interesting look at the effects of the radio antenna.
It could be the compounded effect of the snow or just the base of the antenna - air coming up over the screen and then being spread by the mounting base which is right at the front.
Also ponders.
EDIT - just at the top of the screen is a dip - a channel for drainage.
Old 01-22-2013, 03:53 AM   #246 (permalink)
The PRC.
Tried before in plastic but the issue is attaching it - there is no tailgate on these cars, just a glass hatch.
Old 01-22-2013, 07:39 AM   #247 (permalink)
Team m8
Also ponders.
On my e36 coupe, the Radio Ariel was built into the windscreen pillar- actually INSIDE the car..could you do something similar- really just a case of cutting the cable shorter and some earthing in behind a trim panel?
I'm assuming the hatch has some hinges at the top- can they be unscrewed and a thin piece of metal be inserted betwen the Glass and the hinge? means you could mount to those points, have U brackets of metal coming out, allowing you to build a frame off them? It may also mean the Kamm lifts up with the hatch and doesnt get damaged?
I've done a rough sketch.. (I'm closer to Piccasso than Monet..)
Old 03-01-2013, 12:10 PM   #248 (permalink)
The PRC.
A little "incident" the other week - VW Up! drivers
Old 03-01-2013, 12:17 PM   #249 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
??? Nothing happened ??
Old 03-01-2013, 12:18 PM   #250 (permalink)
The PRC.
Looking for a replacement - there are shorter ones but the base is going to be tricky.
It is more or less like this, will take a ponder. I'm kind of reluctant to move the tailgate too much as the bugs are prone to leaky rears (steady) but mine is dry so far. And it is inside the warranty, and new, and shiney...
I did ponder replacing it with an (older) Diesel Aygo from Fife the other week...
