Old 03-01-2013, 06:01 PM   #30 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by wmjinman View Post
Not entirely sure, but it seems I read on here somewhere that there's an "optimum" intake temperature (for that person, at least), and I'm thinking it was like 90 to 115 deg. F. I'm pretty sure you don't want the intake air to get TOO hot - detonation problems, etc. And I'm guessing air right off the exhaust manifold could easily get to 300 degrees F or more, which would probably be too hot.
Good points, all. I do not remember reading about any "optimum" temperature, as such, but pre-ignition / detonation are things to steer away from.
Preventing overly hot temperatures was one reason I went with a heater core-based heater, as opposed to an exhaust manifold-based heater. It'd be near-impossible to get 300 F out of coolant (and if you're getting that high a temperature out of coolant, you've got other issues...) Another reason was that it was easier to route coolant hoses than it was to route air hoses.
As for the actual temperature? Your guess is as good as mine. I do know that my truck seems to love 130 F as its intake temperature. I would go higher, except that might start wandering into pre-ignition / detonation territory.
