Old 03-01-2013, 07:22 PM   #13 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by wmjinman View Post
Oh, also - it seems getting an oil pressure readout on the thing isn't going to be simple, either... The ScanGauge doesn't seem to have any provision for it, even in the customize-able "X-Gauge" menu. And according to the mechanic, there's a weird type of nut holding the "oil light" sending unit on, so it wouldn't be a simple case of plumbing in a pipe "T". That was another big reason I abandoned the 20 weight oil for this change.... not being able to monitor oil pressure was just "too much"..
The ScanGauge wouldn't be able to get an oil pressure reading even if it was capable of it. The sending unit for the light is only a switch that turns on the oil light below 4 PSI. Unless the newer Suzuki engines changed a lot, there should be multiple oil ports on the block that can be used. And removing the factory pressure switch should be easy. I've read that tees aren't the best way to add a gauge, they can break from vibration.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
wmjinman (03-02-2013)
