Old 03-02-2013, 12:17 AM   #197 (permalink)
RatherDashing
i got the tool off amazon anyways for less than 15 bucks and it came within a day or 2. looking at the teeth of the belt tho they look ok. im taking a better look at it tonight and am going to rotate the belt around and check to make sure no teeth are missing or anything. but with not too much pressure i can slide the belt back and forth. the previous owner said he thought he replaced it. my dad said it looked like it was in decent shape thats what it looks like upclose too. but if thats the case iv been reading thru the repair manual and will see about trying to tighten it if its too loose. and im bout to take the distributor off and take it apart since new one is on its way. test the ignition coil and such. also going to do the valve adjustment.
