well im definetely going to wait til tommorrow to finish this. after few hours of messing around and learning how to find tdc i think i understand that now. but the feeler gauge from autozone i got makes no sence.
i loosen the locknut and turn the screw(this took was tremendous help that i got for this)
and gradually turn the screw to make sure that the .007 one fits in the securely, little drag to pull it out, but at same time its not like really loose in there as well. from reading online this seems to be the right way to do it. and to double check that procedure the .008 one shouldnt fit. well it still does. im completely confused by it and worked at that for a while and decided im going to get the one from sears for 10 bucks with the edges that are angled. with this one they are all flat. or is it that im doing this wrong?
