Originally Posted by aerohead
The 10% section angles on top are correct and the 10% section position labeling is right on as well.(these lower values designate the percentage of the original aft-section of the 2.5:1 streamline body of revolution carried right down to the mirror-image position of the ground plane)
Nice work you two,thanks a lot!
PS I've brought the Gen-II 'Template' today for scanning.Perhaps it won't muddy the waters too much.
Thanks for confirming. I had a feeling you would show up to keep us straight. I will change the template now.
