Old 03-03-2013, 05:46 PM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by SpeedyCorky View Post
I have a grill block similar to yours. sometimes my HX runs a bit hot - and when it does, it usually has trouble getting into lean burn. I keep an eye on temps of course, but I havent experimented much with using the heater to cool things down..... i'll try it for a few weeks and let you know
Great. The trick with the cabin air recirculation selected but without running the fan was the biggest surprise. I expect it'll work for you too. I also found that I could set the heat level in the middle between hot/cold and get a predictably more modest effect. I like the idea of keeping coolant temps in the low and mid 190s.
