pretty sure only the 5 speed had lean burn, different ECU as well, the ECU on the insight with a CVT is different, with a goal of clean exhaust over better mileage, so swapping in a 5 speed transmission is going to be hard and after fixing the battery pack you'll wonder why you didn't just spend the extra money and get rid of the gas engine all together.
