Old 03-04-2013, 09:15 AM   #2 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
If your goal is avoiding damaging the new batteries, the best advice is to monitor them while driving, rather than estimate a range and "hope" it's correct.
You want to avoid drawing a 12v lead acid battery below 10.5 volts under load -- a.k.a. the battricide zone.
You should get a Pak Trackr or similar.
I use a DIY LED bar graph to keep an eye on (avoid murdering) my small 48v pack: http://ecomodder.com/forum/showthrea...raph-8216.html
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
Cobb (03-04-2013), Ryland (03-04-2013), srvweb (03-05-2013)
