Originally Posted by mechman600
I was assuming the use of a pre-DPF engine. I don't think I would risk running bio-D in a common rail engine - the tolerances are too tight and the room for error is too great. Consider that the secondary filters are now, what, 5 microns? 3? I forget. A set of injectors and a HP pump head would cost you about $4500 + labor.
Believe me, I have changed a few!
The tolerances in the CR diesels are irrelevant, if the filters keep debris out of the fuel system, you are fine. Biodiesel is a liquid with smaller molecules than a set of diesel hydrocarbons.
I've been burning B100 and blends in my Jeep CRD for 80k miles with no fuel related issues so far, aside from a gelling incident in below zero conditions. Not to say nothing will eventually degrade as a result, but there are lots of dead ones run on straight petro-diesel.
I hate the smell of diesel smoke too, but I have grown quite tolerant of the smell of biodiesel, much less acrid, and less visible too.
