Old 03-05-2013, 04:25 PM   #14 (permalink)
MetroMPG
90 day: 70.75 mpg (US)
90 day: 62.14 mpg (US)
Note on shifting to/from D/N - in most cars, you DO NOT need to press the button on the shifter. You just bump the selector ahead or back - it will stop at N, and stop again at D. This is safer than pressing the button: you don't need to take your eyes off the road to monitor which gear you're going to, and you won't accidentally select R or a lower D gear.
(I'm not 100% sure if all Hondas behave this way. I've seen some Fords & Volkswagens that require a button press when they shouldn't.)
