Old 03-06-2013, 04:08 AM   #53 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
This was posted in anotehr thread ( #10! by AndrzejM)
Originally Posted by JethroBodine View Post
320touring- Does your fuel pump use an electric shut off solonoid on the end of the pump? Mine does, but is a bit older than either of yours. Mine is a "CR" code engine, making it an 80-82 engine, no turbo. Anyway, mine has a solonoid and I run the power to that solonoid through the contacts of a relay and use that for shut-off/DFCO engine braking. Works great( so far).
Yeah I have an electronic shut off solenoid (I think!- can you post a pic so I can confirm? still new to diseasals!)
I can recommend a turbo
My AAZ is in need of some fettling before I look at what you're suggesting-
The Glowplugs are rubbish- so if the block got too cold on an extended glide/braking event, I'd be having fun re-starting
The engine Bay could do with more insulation, and I should fit the damn thermostat I have sitting to go in.
Then there are the other considerations:
1. I dont feel comfortable with the idea of EOC/mechanical shutting off of fuel on my commute- the traffic conditions dont really allow for it to be done comfortably, in my opinion..
2. I have, however, considered screwing the idle stop out to drop the hot idle down from 1000rpm- thus lowering my fuel consumption during E(on)C/braking events.
I know its a half way house, but until I'm entirely satisfied with the ability of the car to start/stop on demand, it'll do.
I'm away to scour your thread for further ideas!
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
