Originally Posted by 320touring
Yeah I have an electronic shut off solenoid (I think!- can you post a pic so I can confirm? still new to diseasals!)
Yes you have an electric shut off solenoid. It's located on the top of the injection pump, close to high pressure fuel hoses.
I think that it could be done with a simple switch for testing and you have a manual DFCO then and a kill switch. Or you can geek more and build a fairy simple electronic device with a switch for getting "throttle pedal released" signal and a signal from an alternator to get revs/min signal. Then if you have revs like above 1000 and throttle pedal is released it gives DFCO signal to the solenoid to cut the fuel off.
