Old 03-06-2013, 08:08 AM   #55 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by AndrzejM View Post
Yes you have an electric shut off solenoid. It's located on the top of the injection pump, close to high pressure fuel hoses.
I think that it could be done with a simple switch for testing and you have a manual DFCO then and a kill switch. Or you can geek more and build a fairy simple electronic device with a switch for getting "throttle pedal released" signal and a signal from an alternator to get revs/min signal. Then if you have revs like above 1000 and throttle pedal is released it gives DFCO signal to the solenoid to cut the fuel off.
Worth investigation then:0
Thanks for the info
Also, going to phone my tame mechanic to get a quote for doing the timing belt- want that done before I start playing with boost and fuelling
they will come after the suspsneison is replaced (possibly this weekend!)
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
