03-06-2013, 02:28 PM
#25 (permalink)
I don't think the video is a smoking gun. Looks normal to me.
A rear wheel (with drum brakes) will spin freely with little effort, after a one finger push, and keep spinning. I've never seen a front wheel spin freely.
If you had a dragging brake (e.g. siezed caliper) you'd be able to smell the brakes after a long drive, or you'd be able to feel significantly more heat by touching the wheel near the hub after a drive (compared to a rear wheel).
I thought we already determined that the coasting "problem" is fixed by shifting to neutral.
