The needle rapidly drops two or more inches each time the valve should be closed. May also indicate a misfire.
It's not two inches of drop though.
Possibly bad valve guides. YouTube that one it looks just like your readings.
Nice clock That's a nice upgrade. Vx not supposed to have that. Have you done a compression test? I'm assuming all
Is well. You cold have one injector that has a funny spray I guess. The car is supposed to idle at like 600rpm FYI.
