Old 03-09-2013, 06:51 AM   #11 (permalink)
cRiPpLe_rOoStEr
Originally Posted by IsaacCarlson View Post
The p/s delete is easy. I did it on the olds. I take the vanes out of the pump and disconnect the lines, then refill the pump to lube the bushings and loop the lines at the rack with most of the fluid drained.
Wouldn't be more reasonable to delete the pump and get some manual steering setup for weight savings?
