Old 03-09-2013, 05:51 AM   #11 (permalink)
Originally Posted by IsaacCarlson View Post
The p/s delete is easy. I did it on the olds. I take the vanes out of the pump and disconnect the lines, then refill the pump to lube the bushings and loop the lines at the rack with most of the fluid drained.
Wouldn't be more reasonable to delete the pump and get some manual steering setup for weight savings?
Old 03-09-2013, 09:15 PM   #12 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Oh yeah, but it would also cost a bit.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 03-10-2013, 09:10 PM   #13 (permalink)
Indeed.
Anyway, I see you also did an A/C bypass. What exactly is that? Did you retain the A/C hardware and just disabled it? You might know an A/C usually increases the weight of a vehicle from 60 to 120 pounds.
Old 03-11-2013, 10:59 AM   #14 (permalink)
Team Pontiac
I bought a bypass bracket with a pulley on it and removed the A/C equipment. I will do the same on the buick unless I can reroute the belt.
1991 F-250:
