Old 03-09-2013, 03:57 PM   #235 (permalink)
RatherDashing
Originally Posted by Rusty94cx View Post
No the vac in the vids arE 21 and 22 I thought. Bad valve guides don't worry though my money is on the 02 and or exhaust manifold leak. There are a few different ntk o2 and the are the same pn but different 23400 p06 p07 po8 ect. Search vlx build slowand ugly talks about it. Make sure you have the right one. The injector would be the spray pattern and you wouldn't see that by just looking. Alot of guys have the stumble and never seem to fix it. Google hondatech stumble and not 02.
Definetely something im going to check tmmrow. i double checked and i do have the p07 ecu.cant remember the exact numbers on the o2 sensor going to check as well
Im wondering if the timing belt maybe skipped a tooth and waitin on the part to get pulley off monday.might be causing the hesitation.
