Originally Posted by Piwoslaw
Unfortunately PSA doesn't make a hotter thermostat for my engine, and the one it does make is wrapped up with some sensors in a plastic housing, so no way to. I could make an openable upper grille block, but that would be overkill: the lower grille already has two independently openable blocks.
Any ideas? Maybe a partial block for the summer?
Add auxiliary thermostat, it's a proven trick.
Renault B14 engine uses radiator hose thermostat which opens at 89 C. Locals are installing these to commonrail mercedes diesels to get the temp up. You'll find a picture of it by searching with a word "letkutermostaatti"
edit. Found Wahler product codes, they'd be 3029.86 3029.89 and 3029.92 for different temps.
