Old 03-10-2013, 10:32 PM   #44 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Thanks!
The sliding door is just a cardboard template so far, so it's only "manually adjustable" (like at a stop light) . I drove ~200 km this weekend (target speed 70-80 km/h / ~43-50 mph) and that much open grille was enough to keep the engine temp normal (~198) with nice spring temperatures of 4-6 C (~40-46 F). I started out with the block fully closed, then opened it at the first stop after the engine came up to temp. (Yes, I also need a coolant / transaxle heater.)
I was mad though: no lean burn!! Had to drive slower than normal to get good numbers. Grr. Not sure if it's because it was too cold (I have read that L.B. only works at ambient temps above 5C (if I recall), or because IMA is offline after throwing codes because the car sat unused for ~3 months this winter.
Anyway, enough grumbling. I still got ~85 MPG (US) round trip.
Next steps: this week, cosmetic work on the lower block.
