Old 03-11-2013, 10:58 AM   #65 (permalink)
svt98t
Neutral is my favorite
The Black Pearl - '03 Mercury Marauder 300A
Team Panther
Land Yacht - '08 Lincoln Navigator L Ultimate
90 day: 15.89 mpg (US)
Tank of Justice III - '97 Ford Crown Victoria HPP
Team Panther
90 day: 24.84 mpg (US)
PI Intake Manifold Swap = Victory
I'm sure I had a blown intake manifold gasket on the drivers side. All the white smoke was coming out the drivers side tail pipe. And it's had a history of issues centering around the #8 cylinder.
I used this opportunity to swap out intake manifolds and a few other things in preparation for the the PI motor swap.
Here is the blown gasket:
No bueno.
And went from this:
To this:
Side:
Other side:
In weight reduction news, I removed 34 lbs from the vehicle.
The old manifold weighed 30 lbs; the new one, 17 lbs, for a 13 lbs savings.
I also weighed the old A/C compressor versus the A/C delete kit: 13.6 lbs savings.
I removed the A/C dryer and some A/C lines: 7 lbs savings.
Next is to remove the A/C condenser from the header panel. That will be worth some more savings as well.
I'm trying to get my aluminum engine block by the end of the month. I found an even lighter version (73 lbs) and want to use that.
Yeah! Back on the road!
-ryan s.
1997 Ford Crown Victoria HPP- "Tank of Justice III" 194k - 578.9 miles on ONE tank
2003 Mercury Marauder- 63k, not so fuel efficient; #1,548 of 11,052
2008 Lincoln Navigator L - 244k (don't ask about mpg)
