Old 03-11-2013, 01:56 PM   #18 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Search the AeroCivic thread on the question of heat/coroplast. His exhaust has been fully enclosed for years.
I'd start with the partial grille block if only because it's quick 'n' easy. Instant savings vs. the more complex parts you're considering.
I think this might be what MetroMPG was talking about... Not sure though.
Originally Posted by basjoos View Post
Coroplast is made of polypropylene, which has a melting temp of 340F (173C). I have it within 2" of exhaust components from the exhaust manifold to the catalytic converter and within 1" of the muffler where the exhaust temps have cooled off a bit. I used aluminum sheet (roof flashing) for portions of the underbody that are closer to the exhaust system. The main consideration around the wheel/suspension area is to allow space for the full range of movement of the suspension and the lock to lock pivoting of the front wheels.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
