Old 03-12-2013, 10:25 AM   #242 (permalink)
RatherDashing
both are quite lameee. transmission already needs replaced so im going to try and clean it out. i know exactly where the vss is but not sure how it exactly comes off. i think i had it off when i was refilling trans with fluid. but ended up filling it from the side hole instead and not the vss route
possible i didnt reinstall it right.
other one is o2 sensor one of my worst fears. since it does look fairly new i am going to rent the o2 socket remover again and try blowtorching it and air compressing it clean. if not a new one later it is
