Old 03-12-2013, 07:10 PM   #14 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
From what ive seen and looked at myself, without any other knowledge about the car. You could block off the upper and lower opening completely, and leave the middle opening of the main grill open completely without any adverse affects. You get smoother transition over the hood, and less debree through the lowest opening.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
