Dave,
Simple isn't always the best course of action.
![Smile](/forum/images/smilies/smile.gif)
Unfortunately the stock CRX HF is well on its way to extinction. I was fortunate to get one that is completely stock. I'm not much for "classic" cars, nor do I have the ability to keep things looking new for a long time (and still use it). But I would like to try my best to give my CRX the option to be completely stock, and in as good of condition as I can manage. It's going to be QUITE a challenge for me, personally. But I want to do my best. I can always decide down the road to do irreversible things to it, but I can never go back, after it's done.
Plus I see this as a good opportunity to learn another good skill.
I made some progress on the wheel covers today. The lug nuts are drilled, and the covers are drilled too. I realized I didn't have all I needed to epoxy the nuts.
I liked Tango Charlie's
suggestion to use cardboard to hold the lug nuts in place while the epoxy is drying. So I made a make shift holder type thing.
I cut holes that are a bit too small in a box I had (I cut the end of the box off). It's made out of extra thick cardboard. Then filled it with strips to give the nuts something to rest on.
![](http://i1063.photobucket.com/albums/t513/myrefugeisintheLord/CRX/DSCN1774_zps9836e8e9.jpg)
Does that make sense?
Then I took a few minuets to figure out a way to hold the lug nuts in place while I'm trying to drill holes in the tops. What I figured out was using the spare tire and a spare lug bolt to make a holder. I had to use a spacer on the lug bolt to make it work.
More then half of the lug nuts don't have the holes perfectly centered. But hey, I'm not a machine!
![Wink](/forum/images/smilies/wink.gif)
It'll be fine.
Then I got the covers drilled. (These pictured turned out pretty bad, I'll update them soon.)
They are serving trays from Amazon. $7 a piece, which is more then I wanted to pay! But I was set on having black, and it seemed like the best choice. Plus it's readily available, so I'll be the guinea pig and try them out for everyone.
![Big Grin](/forum/images/smilies/biggrin.gif)
I already don't care for them much....
