Originally Posted by yostumpy
Yes I want to interupt the boost hose to the FIP, so that it can be 'partially ' restricted, in a similar way to the VW 'umwelt' eco engine IIRC. but then be opened up to give me max power when needed.
IIRC, the "umwelt version of the AAZ had NO boost pin, as the turbo was essentially just used to make sure there was sufficient air for a total clean burn. The turbo offered no performance (HP/Torque) gains
