Old 03-13-2013, 11:44 AM   #13 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by wdb View Post
All the turbocharger does is increase the amount of air entering the combustion chamber. Either the computer, by keeping the injector open longer, or some other mechanism, adds fuel to match the extra air. Stopping the additional fuel altogether, with no other compensating changes, could cause you to run dangerously lean.
That is wrong. Diesels ALWAYS run lean - because diesel fuel is designed to be ignited by the heat of compression and burns slowly regardless of fuel/air mixtures, this allows them to burn fuel completely and with greater expansion, resulting in better fuel efficiency.
I'm not coasting, I'm shifting slowly.
