Old 03-13-2013, 03:33 PM   #224 (permalink)
TheSGC
I got the heater installed and bled the system like crazy, so it should be fine now. I spent a good 20-30 minutes with the over flow tank held up high and the farthest connection from the tank in the air and fill from both ends until the air bubbles stop. Then I shook all the lines until the levels went down and refilled.
At the end I could adjust the levels of fluid in the reservoir and the furthest tube by raising and lowering them, showing me that the system was full. Then I let the pump run for a few minutes and I now hear the fluid running through the heater core in the cabin.
Good new is I might not need the heater for much longer, its about 65F out today in the sun and spring is coming!
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
