Old 03-13-2013, 04:12 PM   #6044 (permalink)
jackbauer
jackbauer's Avatar
Would it be possible to mode the code (here i go again!) to use the htfs 800-p lem current sensor? This sensor works on 1.125*Ip/Ipn as opposed to 0.625*Ip/Ipn from the hass 300s and can measure upto 1200A.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
