Hey!
Sounds great so far, I want to see the performance of your E39 with this big controller.
Which FETs/IGBTs are you going to use? And do you want to cool it with water, or just air cooling?
I've also sent you a PM, but I think you haven't read it so far. I was asking about your emulation of the crankshaft sensor, I've never seen someone doing that, so I don't know why you do that? I only see everybody to throw the original motor ECU away, because it's not needed, even for A/C and so on?
Thanks
