Old 03-17-2013, 06:42 PM   #6050 (permalink)
jackbauer
jackbauer's Avatar
I'll be using 3 or 4 CM600du-12f 600v 600a igbt modules and liquid cooling. The reason for retaining the ecu is that its an integral part of the can network in the car. With no ecu the dash doesnt work etc.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
