Old 06-18-2008, 11:33 PM   #19 (permalink)
Duffman
Originally Posted by Lazarus View Post
Allan interesting if we can stay focused and keep the discussion on industrial hemps as an alternative fuel. What is the cost to produce a gallon of hemp oil?
Are these figures correct to produce just the oil?
Grown for oilseed, Canadian grower's yields average 1 tonne/hectare, or about 400 lbs. per acre. Cannabis seed contains about 28% oil (112 lbs.), or about 15 gallons per acre. Production costs using these figures would be about $35 per gallon. Some varieties are reported[iv] to yield as much as 38% oil, and a record 2,000 lbs. per acre was recorded in 1999. At this rate, 760 lbs.of oil per acre would result in about 100 gallons of oil, with production costs totaling about $5.20 gallon. This oil could be used as-is in modified diesel engines, or be converted to biodiesel using a relatively simple, automated process. Several systems are under development worldwide designed to produce biodiesel on a small scale, such as on farms using "homegrown" oil crops.
Production costs totalling $5.20/gal (And this is an old study)
Well thats about the speed of it I guess. Diesel would probably need to be near $8 for this to be profitable as that $5.20 would be around $7.00 now (note: number pulled out of my ass) given that fuel is a significant input cost in farming. Plus there would be transportation costs to market and nobody is going to touch the stuff unless there is some profit in it as well.
