Originally Posted by MilesPerTank
Are you really just randomly adjusting it to "look right"?
I should clarify, I've had other mpg gauges in my car and various fillups so I already have a good idea what mpg it should be @50mph. The adjustment isn't technically random, you adjust the vss and the microseconds/gallon up or down by the percentage that the display is off. Same technique will apply at fillup, except it should be possible to get the computer to help out a little.
Originally Posted by bockwho
...it is caused by the horn .. after some testing today no matter where the unit is in the car if you sound the horn it several H's and M's will go full black..
Someone remember to test their horn
