Old 03-18-2013, 02:19 PM   #22 (permalink)
Talon
Builder
LCA progress
I got the first of four A-Arms done this last week, a LCA. It came out of the jig pretty nicely, only about 1/64" from perfect, if I can get the other LCA this close I am good to go. The lowers are made from 3/4" extra heavy tube, which is the same as most aftermarket off-road pieces for full size trucks. The outboard end of the LCA is tapped for a 1/2 rod end and set at 10 degree of tip to match the KPI angle. I figure that the Lower Control Arms is one of those places I don't want to cut any corners on as far as strength goes. I'll sacrifice a bit of weight for stout. They are going to be exposed and flying down the road at 70 mph 6 inches from the ground. . .
There are some brake parts and spindles in the garage now as well, along with a bunch of "maybe" stuff, like e-brake handle, brake master cylinder (boosted), seat belts etc. The poor donor is looking kinda ratty now, and will get hauled off soon. I just need a few more parts from the front suspension.
I am going to try and use the rear spindles from the donor as front spindles. I'll need to fabricate knuckles to bolt the spindles on, but I think I can do that.
Anyway, here are a couple shots of the lone LCA that I completed.
TALON §
ID:	12712   Click image for larger version
