Old 06-19-2008, 01:04 AM   #215 (permalink)
ttoyoda
ttoyoda's Avatar
I'm at 1/4 a tank used and 250 miles.. well see how it does.. im not expecting to much as the c pillars arn't even close to smooth or shaped fully yet and the rear window section isnt in place so its not a idea tail yet but a tail none the less..
At low speeds the surface finish is not so important. The roughness may be keeping flow attached where it would otherwise seperate. By the way on your wheels.. be aware that the center hole size and the offset should be compatible on whatever you pick.
