Old 03-19-2013, 06:05 PM   #6052 (permalink)
jackbauer
jackbauer's Avatar
Some sensors are more important than others. The crankshaft sensor tell the ecu the engine is running so is the most important. Others such as oxygen sensor etc are just used for emission control and can be ignored.
Possible name for the new controller : "Re-moc 1200" Well? What ya think?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
MPaulHolmes (03-19-2013)
