Originally Posted by Vekke
I used angle grinder with 0.8mm blade to cut that 2mm thick sheet. It worked nicely.
Do you think an angle grinder is better than scoring it with a blade?
I think if I did this for a living, scoring it would be better. But since I am a novice, the angle grinder might be bet best approach. Similarly to tile cutting. Scoring/ snap cutting is faster and does a great job, but since I am a novie, I find a diamond plade on an angle grinder seems to be easier for me and I waste less tiles!
