hell, the 2011 fiesta has Cd of .33, but id love to have that Vette!!! Just for styling or not it still goes faster than the ford anyday, and looks so simplistic on the inside(maybe full HD display?). If i could, id love to mimic it in almost every way, but redo the "fastback" portion of it and elongate it to match template, smoothy wheel covers, and give it a smooth underbelly(assuming it doesn't have one for 70's tech), give it a decant little 6cyl with a double overdrive... who knows whats possible.
Curious of the influence, if by adding a small lip tail section would of had on it?!
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
