I've been looking for some thermo probes, but can't seem to find any that would work. They all seem to only read to around 125-150 degrees. Ideally I would have the probe setup in the engine bay with a wire through the firewall and a display in the cabin, so I can see it in real time.
Do you have a link to the one you have or the one I am describing.
Thanks!
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
