Old 03-24-2013, 08:09 PM   #39 (permalink)
jeff88
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Why 45%? Or are you trying to increase your FE by 10mpg and the percent is not your concern?
In terms of maintenance, definitely check your battery. If you have even a less then perfect battery, your alternator will be working harder, negatively effecting your FE. Make sure your oil and transmission fluid are not only "fresh", but not too full, it will make the bottom end of your engine and transmission work harder.
Do you have LEDs?
In terms of aero, I would do a rear diffuser. It is relatively simple, easy to take off, depending on how you design it and can be fairly well hidden if you want it to be.
What part of Oakland? I assume you are staying well clear of the "Maze".
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
