It is not easy finding thermostats that will allow exploiting the high boiling point of the glycol mixture.
You'd also have to temper down your heater/defroster temps. I have a 203 degree stat and the heater will burn your fingers and the defroster will crack the wiondshield in extreme conditions.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
