Here's the point in the design process where Elio Motors went from a semi-enclosed to enclosed rear wheel:
I'm not sure which I prefer. A convex bubble on the back might be necessary to fit across the back of the tire.
Are you going to go with Polymetal?
Well for the underbody will go with first the sign cardboard stuff.
Do some testing get it right then go to the polymetal. That stuff is strong and no weight
also got the battery tray added Once All the welding is done more to my home
and stat a little painting on the inside and putting together but first get it running and to stop. Pics soon
