Old 03-27-2013, 11:23 AM   #1 (permalink)
Tonys9
Results not changing after calibration
I originally setup my MPGuino using calculated flow + 500us delay. Then recently on the first controlled fill up I got a new us/gal figure (4% higher).
This then lead to what I'm calling nonsence figures for MPG on the flat (around 60-70 for this car is just wrong), also my gph went from 0.31 to 0.21.
I then measured delay using the current probe methods and tried to re-adjust but it didn't make any difference. Finally I changed the delay and us/gal figures back to my original setting but still nonsense results including gph +mpg.
The original figures are stored, I've tried power cycling, tank and current resets but no change. Seems I am no longer able to change the numbers used for calibration, although the displayed numbers change ok.
Am I doing something wrong? Is my unit broken, does it need reprogrammed?
I'm an Electronic Engineer BTW, not familiar with the software though.
1995 Volvo 940 SE 2.3 Turbo estate (petrol) Running MPGuino from Dec 2012
Peak flat: 42mpg
Long run average: 37.4mpg (Jan 2013)
Typical average: 24mpg
UK based, gallons are imperial unless otherwise stated
