Isn't an airplane conversion outside the remit from the Original Poster?
Originally Posted by Cobb
Has anyone really put much thought into this vs just tossing out makes and models of cars? Is there a car with better aero than the Prius? Is there a more efficient and clean GAS engine than what the prius comes with?
Originally Posted by sidecar
Prius is perfect in some ways, it is already a proven aerodynamic shape of what is a full sized 5 seat aluminium car, and it conquers aspects of power brakes and power steering quite neatly.
As I said in August, I'd drop the weight of the Prius (100s of lb?) by pulling the complete drivetrain and swapping in a 36hp VW boxer and transmission. You could even put it in the front, using parts from
The Blackjack ZERO. You'd wind up with equivalent-to-stock mpg; but that isn't disallowed by the remit, right?
I'll go further. Convert the boxer 4 to a
Miller cycle compressed air hybrid, and use GSXR 600 throttle body or port injectors and crank-fired ignition.
Performance would approximate a diesel Prius, would it not?
EDIT: Here, I Photochopped it:
