03-27-2013, 05:08 PM
#215 (permalink)
Grand Imperial Poobah
Originally Posted by Mika
Please tell me that the new concept truck is going to have only one diff and a liftable tag axle. Lift Tag with diff lock has more than enough traction for most of your driving conditions, and saves a lot of weight and has much less drivetrain losses. Scandinavian people has survived with them from the 60's, so it would be about the time that americans wake up and see the advantages too. Trailer could have liftable second axle too, wouldn't hurt to have only two tires rolling when empty.
Also, would such aerodynamic truck manage with electrical water pump and electric fan? I-shift has too proven its worth here. Also, are you familiar with the teardrop trailer?
Just playing with ideas here, let me know what you think.
Hi Mika -
I'm not on the welcoming committee here, but welcome to the forum.
Yes, the new truck will have only one differential and a tag axle. Not sure if it will be a lift axle yet. There are other ways to get traction to the differential.
Definitely a high-voltage electric fan. Possibly a High-Voltage water pump.
The teardrop trailer would not work for general freight here in the good ol' USA. The shippers of high-cube loads use a 53' x 102" rectangular trailer configuration in their load calculations. And we have 14' underpasses on highways, so a teardrop either wouldn't fit underneath, or it would hold way less freight to actually get under the overpass.
Bob Sliwa
"Like a Midget at a Urinal, I knew I was gonna have to stay on my toes......."
http://www.airflowtruck.com
