Originally Posted by Swordsman
As for the kammback extension, it has to be this short or I lose access to the trunk. I'm really not sure how to brace it off. I refuse to drill holes, so I'll be relying heavily on 3M double-sided trim tape. Maybe some long aluminum brackets tucked under the trunk seams or something....?
~ SM
Heres my .02 on the kamm. You could make it longer by adding a door hinge from a house door which would allow you to fold the kamm up or even take off the back half at any time. The edges could lay in the space between the body and the trunk lid. I would think you would need the kamm to be smooth against the body or the wind can and will lift it up and off, but if the kamm was painted black and used black duct tape it would be fine.
