Originally Posted by Gealii
Heres my .02 on the kamm. You could make it longer by adding a door hinge from a house door which would allow you to fold the kamm up or even take off the back half at any time. The edges could lay in the space between the body and the trunk lid. I would think you would need the kamm to be smooth against the body or the wind can and will lift it up and off, but if the kamm was painted black and used black duct tape it would be fine.
Interesting! Hmm, I wonder how I could attach the ends and still lift it up when I needed? 3M'd hoops on the trunk and small bungees?
When it comes to forming the kamm, do the corners
really need to be smooth, or can I simply crease my material and achieve basically the same thing?
~SM
